Vlado, i beg you!
  • #16
    Originally posted by zerofractal
    I want a clip map
    You can get clip map behaviour using displacement:
    It's a snap:
    1) Create a plane with texture coords
    2) Apply VrayDispalcementMod to the plane
    3) Create a B&W or greyscale image (I used a clamped noise for this writeup)
    4) Put the B&W image/noise in the Texmap slot of the VRaydisplace mod.
    5) Check "Use water level" in the VRayDisplaceMod
    6) Change the "Water level" to something other than 0
    7) Render
    The plane will be clipped based on the water level threshold...think of it as a greyscale threshold.
    One thing to note, the water level should be less than the displacement "amount". For my example I used an "amount" of 0.01 (so as to have minimal height displacement), and a water level of 0.001 (to clip closest to black). The greyscale threshold goes from 0 (zero) to the amount of the displacement you set.
    Hope this helps.
    Greg Tsadilas
    VFX Supervisor/CG Supervisor
    • #17
      a clever use of displacement mapping... gotta remember that one...
      Nice find Greg !!!
      - Geert -
      www.3DIGIT.be
      3Dprinting in full color !
      • #18
        but is the displacement method as fast?
        • #19
          It certainly is, you're just dealing with simple B&W images here, much like clip maps.
          Greg Tsadilas
          • #20
            whonder how will it behave with million instanced leafs on a an instanced forest. How would it compare to:
            - Vray Map w/ mask in the refraction slot and IOR set to 1.0
            - Std Material w/ opacity map (the old fashioned way/ which is extremely slow on vray)
            - Blend material using the leave as mask
            - Vray Displacement w/ Greg's method
            Alejandro Gonzalez
            alejandro.gonzalez@zerofractal.com
            Zerofractal - Visual Communications
            New Website! www.zerofractal.com
