Option to override material effect id
  • Option to override material effect id
    Material effect id's are a huge part of creating matte's while rendering - however 3ds Max only allows the user to assign up to 15 material effect id's. It'd be awesome if within the VRayMtl options rollout there was a checkbox to "override effect id" then we could use 0-65,000 to create as many material matte's as needed.
    Mockup below. The "Effect ID" spinner would be disabled unless the "OVerride material effect ID" option was ticked.
    Christopher Grant
    Director of Visualization, HMC Architects
    Portfolio, ChristopherGrant.com
    Thanks for the suggestion; I didn't realize this was limited to 15 in the interface; internally V-Ray can work with any 32-bit integer for this, so it should not be hard to implement.
      That's great to hear! Hopefully that turns out to be the case - it'd be a huge improvement for our workflow and I suspect for many other studios too.
      Christopher Grant
        So this is now done for newer builds.
          Wow! Thanks!
          Christopher Grant
            This will be fantastic! Thanks for the suggestion Christopher! And thanks to Vlado for implementing this!
            This will be a huge time saver for us and we can now fully get away from object IDs.
            Troy Buckley | Technical Art Director
            Midwest Studios
              This sounds great! Is there a new build of VRay 1.5 with this implemented, or will I need to wait until 2.0 is released? Many thanks.
              -Andrew
              Andrew Martin Visualisation
                Right now this is only in V-Ray 2.0; the 1.5 branch only gets bug fixes.
                  Perfect, thanks to christopher for the incentive and thanks to vlado for fixing it fast!!!
                  I was waiting for a long time for a possibility to get more than 15 mat id`s.
                  T H A N K Y O U
                    Ha, only just discovered this feature! Perfect! I have been running out at 15 and starting on object ids, ever again!
                    To confirm, you simply leave all the 3dsmax material effects id at 0 and number them all up through the option, overide material effect tick box?
                    Perfect again!
                      What the hell? I hate it when I overlook an awesome feature!
                      V Miller
                        This is correct, yes.
