Maybe I'm suggesting something that already exists, but would it be possible for vray to return the info created in the vraylog as variables to access in maxscript? Also, is there any way to save out this data, and/or the framestamp data into metadata within the EXR rather than as raster data over the RGB pass?
a) Maxscript access to vray logs + b) metadata as well as framestamp ?
The log file is just a text file, so ideally you can parse it from MaxScript directly. It's a good idea about the metadata, will think about it. Also, I think you can already write metadata into EXR files written through the 3ds Max frame buffer.
