render region selected
  • render region selected
    i always wanted this to work with animated cameras.. as in the region will move and adjust to keep the selected object as the camera/object moves. useful for rendering out repair patches for glitches in a sequence.
    probably i should just use spherefade or something..
    Does it not work right now? I remember this worked at some point when using the 3ds Max "Region selected" option - at least for animated objects.
      mm last time i tried to render a sequence with this method, the region didnt update to track the object.. simply staying where it was on frame 1... that example was with a camera pan past a static object though... and it was also about 6 months ago.. i just saw someone mention region rendering and it reminded me of the feature i wanted.
