Maping Fog Color (Vaymtl param.) a set this parametr form texture. This is posible?
Maping Fog Color
Since fog is 3D this is pretty complicated. There was a thread about this a while ago.
You might want to try using a blend material though. Set up a gradient, and use that to blend between two fog colors.Torgeir Holm | www.netronfilm.com
As far as I recall, fog mapping has to be done as a 3D volumetric texture to be correct, so no 2D mapping. The 3D texture would also take a long time to render.
Did you try the blend map trick?Torgeir Holm | www.netronfilm.com
