Vray distance texture -ability to adjust distance gradient by (animatable) curve
  • Vray distance texture -ability to adjust distance gradient by (animatable) curve
    Now when i use this texture i can only adjust the distance which is basicly linear gradient from black to white. So it will be very usefull when there can be posibility to adjust distance gradient by animatable curve. So I can also extends the full affected region, and do intensity of gradient like I want.
    This texture is realy perfect VFX like doing animatable masks, but it should have some enhencements like this. Also i figureout when i do 2 spheres which interpenetrating each other and i attach it to one edit poly object and this object i use to drive distance texture for the plane, so there is bug when i select inside solid in material, it dont fill whole poly object but do something like boolean holes inside.
    You can always pipe it through an Output map and adjust the curves there.
