hello vlado
Is it possible to add a "source " input for grabbing the object which is the source for the map?
like this you could use the map without including it in a material itself. today it's only working when you add the map on the material which is applied to the object (carrier) which should interact with the objects to generate the distance.
best regards
themaxxer
best regards
themaxxer
