restricting photon bounces to an area
  • restricting photon bounces to an area
    it would be cool if you could restrict the photon bouncing to a specific area. i'm thinking about an athmospheric bounding-box dummy, for example.
    or maybe some attenuation setting for photons in the light.
    like i have a big building and only want to render a specific part of it from the inside, say the entry hall. bounces for the sun are calculated for the whole geometry, which is slow and takes much memory.
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
    you can limit the memory usage with the max photons settings (higher makes less memory used) You can also focus with the light settings some, I think. For example if u use directional light then make the parameters that it covers only that part you need. Okay there will be some overlapping but at least something.
    Otherwise I dont know, it wouldn be easy, because then how to cover the openings? If a photon reaches the bounding volume how it will bounce back?> Should it have some material, etc. Maybe if you simply just close the "shop" with some planes.
