output passes to separate folders
  • output passes to separate folders
    I know this feature exists in maya, but it's not yet in max. It would be great to have it!
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
    It's in deadline if you're using that - it actually caused me a huge amount of problems when it automatically renamed and repathed elements on submission - totally screwed up another system based on naming conventions
      Actually on that note I've a script I wrote to set up output file names based on a root path for renders, the scene file name and your render element name if that's any use.
        yeah this wish is not for me...
        Dmitry Vinnik
        ShowReel:
          This is added in our "to do" list already.
          Hope it will be implemented soon.
          A related thread :
          http://www.chaosgroup.com/forums/vbu...eperate-folder
          Tashko Zashev | chaos.com
            Hi Tashko,
            If it's not too far down the development line, would it be possible to get the naming based on some kind of token system? Kind of like the %1, %2 %3 type of thing you commonly see in mp3 file tagging? Or even %folder %passname or something along the lines of that?
              It's not impossible, though it is some work... what kind of tokens would you need?
                If it's work then leave it, I've got a lot of it sorted in maxscript personally. Stuff like max filename, camera, element name, date and so on - the type of things that'd be useful for version tracking?
                  multiple +1s from me. Has this not been requested before (a long long time ago)?
                  Signing out,
                  Christian
                    I presume this is when you're outputting separate passes via the frame buffer? Or are you talking about using max render elements?
                      Personally i was hoping for these tokens in any vray related file dialogue
                      Signing out,
                      Christian
                        Ah yes this would be really great!
                        I've always liked the tokens that Softimage uses:
                        http://softimage.wiki.softimage.com/...hTemplates.htm
                        It gives a lot more freedom and flexibility. Note the frame padding as well.
                        If you have the render element token then you would need only one line to set up the shot for all the render elements.
                        An issue might be if you need the render elements in a subfolder of the beauty.
                        Options would be to either use two file name boxes, one for the beauty and one for the elements.
                        Or use a token which will be ignored when it comes to the beauty/rgb_colour image, e.g.
                        D:\[project]\[shot]\[task]\[version]\[renderElemSub]\[sceneName]_[renderElemSub].[framepadding].exr -- For REs in sub-folders. The underscore might be somewhat of an issue though, if you'd want to get rid of that for the rgb_col.
                        D:\[project]\[shot]\[task]\[version]\[renderElem]\[sceneName]_[renderElem].[framepadding].exr -- For everything in its own folder.
                        D:\[project]\[shot]\[task]\[version]\[sceneName]_[renderElem].[framepadding].exr -- The current everything in one folder.
                        Custom creatable and definable tokens like [project] and [shot] etc. would be really useful as well.
                        Rens Heeren
                        Generalist
                        WEBSITE - IMDB - LINKEDIN - OSL SHADERS
                          Maybe offtopic but I have written such script for renderelements, and the problem I have is getting the good options for file formats. Like png 8bit, without alpha, exr half or float, rgb or rgba etc. I can't get these settings working with maxscript, any insight on this ?
                            Yep - I can get formats, it's only decided by the name of the file you put at the end but they haven't exposed certain important parts. For example I use EXR for everything and it doesn't give you access to the 16 bit / 32 bit options or RGBA / integer and so on.
                            All of the controls are listed under the topic bitmapIO in the maxscript docs, but as you say some parts of the image options aren't exposed to maxscript.
                            • #15
                              Well, all options I need are exposed to maxscript, but works totally heraticaly. sometimes works, sometimes not, sometimes do the opposite ... nothing robust
                              -- EXR interface settings
                              fopenexr.setLayerOutputFormat 0 1 -- 0:Full 1:Half 2:Integer
                              fopenexr.setLayerOutputType 0 1 -- 0:RGBA 1:RGB 2:Mono
                              fopenexr.SetCompression 2 -- 0:None 1:RLE 2:ZLIB(per scanline) 3:ZLIB(block of 16) 4:PIZ
                              fopenexr.setSaveScanline true -- false:tiles true:scanlines
                              fopenexr.setSaveRegion false -- false:full image true:region
                              -- PNG interface settings
                              pngio.setType #true24
                              pngio.setAlpha false
                              pngio.setInterlaced false
