Global disable of prepasses
  • Global disable of prepasses
    Hey there,
    I'm often running into cases where I've got prepasses when I'm rendering.
    I have to
    1) merge all my xrefs (which can be a lot)
    2) use zorb script to see if I have sss materials
    3) replace those by vray materials
    4) use VMC to assign interpolation to reflection and refraction and then take it off
    5) save out my xrefs again
    all that to make sure I disable the prepasses when I'm rendering.
    Is there any way to set a global checkbox like displacement etc to tell vray to disable use interpolation or sss? or any way to have a prepass?
    Thanks
    Stan
    3LP Team
    Hi Stan,
    Thank you for the feedback.
    Just want to inform you that our developers are working on options to change some of the materials properties globally.
    I'm not sure if this options will affect the interpolations caused by the SSS material.
    Edit: SSS could be overridden from the Global switches. Another way to speed up the interpolations is to decrease the Prepass rate.
    Tashko Zashev | chaos.com
