My skills with creating furry rugs and carpets are somewhat limited. I have a rug in a bedroom shot which looks 'so-so', but rendering the scene with vrayfur takes around 18GB ram! It would be nice to have some good presets to get you part way there. Maybe a purchasable (?) library of settings?
Presets for vrayhair/fur rugs/carpets etc
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
the VRayFur thing is a bit hit and miss as it depends on couple of things. Even if you have a preset, it may not always work the same as it mainly depends on your geometry and by how much you subdivided it.
For example if you have a rug 1000mm X 2000mm, and you subdivide it into about 50mm X 50mm sections will give you different results if it was just subdivided into 500mm x 500mm sections
But I agree some kind of presets and/or improvements in the fur system will be great. Doing rugs with displacement is so last seasonKind Regards,
Morne
