I played with the vray hairfarm modifier, while it's true that the vray hairs shader look much better then on poly hairs, there is a huge problem with the vray hairfarm mod, and I can't get why nobody flag it out.
I will explain it: In hairfarm, you have the segment hair : normally it's 0 by default, but even at zero, since hair render CURVES , it will still be smooth. normally, for most of my haircut, I put 1 segment and when you apply a kink let's say at 1,0 of strenght, you will get a certain effect. BUT, if you add an other segment, so 2 instead of one, the kink effect became much more stronger and NOT the same, it's changing the whole hair cut.
so the problem is here, when we render with the Vray hairfarm mod, it just take into account the number of segment in hairfarm, so we get just one segment! so it's very EDGY and ugly, for now we can't add segment in the vray hairfarm mod. Hairfarm renderer don't have this problem because he render it has a curve.
So to make it usable, we need it to have an option that we can add segment to the vray hairfarm modifier ( would be cool also if those segments can adjust automatically to the lenght of the hairs so that the smallest hairs dont get let's say twelve segments if they only need 3 to look as fnie as the longer one) , otherwise it's just too much edge we can't use it.
Let me know Vlado if you can add this rapidly
I could make my Daniel Craig use the Vray hairfarm Mtl and show you, I think I would get better result then now
![smile](https://forums.chaos.com/core/images/smilies/smile.gif)
![wink](https://forums.chaos.com/core/images/smilies/wink.gif)
