Autofilling the holes create by clipping plane
  • Autofilling the holes create by clipping plane
    Hello,
    It will be great to be able to fill the hole of the clipped geometries, while using the clipping function of the VrayPhysicalCam.
    Filling the gap of every clipped object in post prod is really time consuming, but leaving it open lead most of the time into client's interpretation mistake.
    If someone knows a script to avoid this, thanks to share.
    Thanks
    I would use Slice + cap holes moddifier for mesh. Just select all meshes and apply 1 slice + cap holes mod.
      Thanks,
      that works for still with different camera but most of the time we use only one animated cam for different angle for still images. Animating the slice modifier may lead to even longer process.
        You could possibly link the slider gizmo to camera xyz rotation and distance to camera clipping xyz coordinates to make it automatic...
          will try it, thanks for the tips.
            The VRayClipper in V-Ray 3.0 can fill in holes generally, although it has problems with overlapping geometry currently...
              You need it, Vlado have done it!
              http://help.chaosgroup.com/vray/help...per_params.htm
