vraytoon as a render element
  • vraytoon as a render element
    Hello,
    It will be a lot trouble less to have the vraytoon as a render element instead of an effect.
    As an effect we are oblige to make several render to take advantage of this, while using it as a render element will be great to extract outline drawing for example.
    Thanks
    It is on the "to do" list... in the meantime, you can use the Atmosphere render element, which also contains VRayToon provided that the outline color is not black.
      thanks, will test this workaround.
