When I try to bake textures with vray material it doesn't work. I tried baking a vraydirt map but I had to put it in a standard material and then adjust the vray camera exposure to get the material right. Is it possible to add it to the wislist? thanks.
Baking vray materials to texture.
__________________________________________
www.strob.net
Explosion & smoke I did with PhoenixFD
Little Antman
See Iron Baby and other of my models on Turbosquid!
Some RnD involving PhoenixFD
Tags: None
instead of adjusting the vray camera, adjust the vraydirt settings while looking at the diffuse render element - and then bake?Brendan Coyle | www.brendancoyle.com
The dirt map is pure black and white. but my render was grey until I increaed camera exposure.
www.strob.net
Little Antman
This is in the viewport render or in the baking render? are you using DR?
If I drop a vray material with vray dirt in the diffuse, onto a teapot - it renders to texture fine as long as you choose the VRayDiffuseFilterMap elementBrendan Coyle | www.brendancoyle.com
