We have a few older render nodes that are still fast enough to use (multi-proc), but don't support Embree. Would be nice to be able to set an environment variable sch that only those nodes didn't use Embree. I am not seeing flickering in my tests of mixing them (but it likely is scene dependent, as I only tested with one scene).
Alternately this could be a command line switch passed to 3dsmaxcmd.exe
Also, how about an environment variable, or just the default behavior) to disable the VFB mouse tracking on render nodes. This way you could leave mouse tracking on at the workstation and the nodes would use the previously selected method (triangulation). Much of the time we find it easier to render WITH the VFB, rather than to turn it off for net rendering (because of how it handles render elements).
Thanks.
Thanks.
