I'd like to load and save .vccglb files in the vfbcontrol with maxscript, but as far as I can tell there is no access at this point. Or am I missing something?
Maxscript access to vfbcontrol Global Color Correction File
In version 3.x you can control VFB via the following MaxScript command:
Code:vfbcontrol() Usage: vfbControl [#help] [#rgb|#red|#green|#blue|#alpha|#mono|#trackmouse|#linkpdp <BOOLEAN>] [#swapab <BOOLEAN>] [#setcompareab "h"|"hor"|"horizontal"|"v"|"ver"|"vertical"] [#loadimage|#saveimage|#saveallimage <FILENAME STRING>] [#setregion <left top right bottom>] [#getregion] Returns <left top right bottom> [#setregion "reset"] To reset/disable region. [#clearimage|#duplicate|#hide] [#getchannelnames] Returns a string[]. Indices correspond with #get/setchannel. [#getchannel] Returns the index of the current channel. [#setchannel <INTEGER>] For Color Corrections: [#clamp|#viewclamp|#info|#history|#pixelaspect <BOOLEAN>] [#exposure|#whitebalance|#huesat|#colorbalance|#levels|#curve|#bkgr|#lut|#ocio|#icc|#srgb <BOOLEAN>] [#ccociovt|#ccocioics|#ccociodd <INTEGER>] [#ocioinputcolorspace|#ociodisplaydevice|#ocioviewtransform <STRING>] [#itemsociocs|#itemsociodd|#itemsociovt|#itemsiccri] Returns list of combo box items [#colorbalancemode 0|1|2|3] 0 - All 1 - Shadows 2 - Midtones 3 - Highlights [#colorbalancevalue <INTEGER|FLOAT INTEGER|FLOAT INTEGER|FLOAT>] [#huesaturationvalue <INTEGER|FLOAT INTEGER|FLOAT INTEGER|FLOAT>] [#cclevels_rgb|#cclevels_red|#cclevels_green|#cclevels_blue|#bkgrimgasforegr|#lutconverttolog|#cciccblackpoint <BOOLEAN>] [#stereo 0|1|2] mode 0 - inactive current mode mode 1 - red/cyan mode 2 - green/magenta [#cciccrenderintent 1|2|3|4] 1 - Perceptual 2 - Relative colorimetric 3 - Saturation 4 - Absolute colorimetric [#setexposure|#setcontrast|#setlevelsmin|#setlevelsmax|#setwhitebalanceval <FLOAT NUM>] [#getexposure|#getcontrast|#getlevelsmin|#getlevelsmax|#getwhitebalanceval] Returns <FLOAT NUM> [#loadimage|#loadbkgrimage|#loadlut|#loadocio|#loadicc|#loadcurve|#saveimage|#savecurve <FILENAME STRING>] [#bkgrimgfile|#lutfile|#iccfile|#ociofile] Returns <FILENAME STRING> For VFB History: [#history <BOOLEAN>] [#historytemppath <PATH STRING>] [#historymaxsize <INTEGER>] [#historyselect <INTEGER>] To select a history image (0-based index) for the commands on the next line. [#historyload|#historysave|#historyseta|#historysetb|#historyremove|#historyclear] [#historycomment <STRING>] For Lens Effects: [#bloom|#glare|#bloomfill|#glarefill <BOOLEAN>] [#bloommode "image"|"both"|"renderelem"] [#glaretype "image"|"rendercam"|"camparams"] [#glaremode "image"|"both"|"renderelem"] [#bloomweight|#bloomsize|#bloomshape|#glareweight|#glaresize <FLOAT NUM>] [#bloomintensity|#bloomobject|#bloommaterial|#glareintensity|#glareobject|#glarematerial <BOOLEAN>] [#bloomsetintensity|#glaresetintensity <FLOAT NUM>] [#bloomgetintensity|#glaregetintensity] Returns <FLOAT NUM> [#bloomsetobject|#bloomsetmaterial|#glaresetobject|#glaresetmaterial <INTEGER>] [#bloomgetobject|#bloomgetmaterial|#glaregetobject|#glaregetmaterial] Returns <INTEGER> [#glarediffraction|#glareuseobstacle|#glareblades <BOOLEAN>] [#glaresetblades|#glarebladesrot|#glarefnumber <FLOAT NUM>] [#glaregetblades] Returns <FLOAT NUM> [#glareimage|#glareobstacleimage <FILENAME STRING>] For Stamps: [#stamp <BOOLEAN>] [#stamphalign "left"|"center"|"right"] [#stampvalign "top"|"bottom"] [#stamptext <STRING>] Where <BOOLEAN> is true|false and <left top right bottom> are integers. Note: Successfully loading a file or setting a numerical value implicitly enables the corresponding option. If you want to disable it, do it after the load/set command. All commands, that make sense to return values, written without arguments return value or list of values depend on comand type.
Originally posted by Crush View PostI'd like to load and save .vccglb files in the vfbcontrol with maxscript, but as far as I can tell there is no access at this point. Or am I missing something?
VladoI only act like I know everything, Rogers.
