Using keywords for Irradiance Map / LC / FrameBuffer Output
  • Using keywords for Irradiance Map / LC / FrameBuffer Output
    Using keywords for filename generation would make sending out muliple jobs so much easier. I am referring to all kind of VrayFiles: Framebuffer Output - Irradiance Map - Lightcache - what else?
    Scenario: 15 camera animations need to be rendered - all the LC files / IR files / Output files are once defined and differentiated by different camera name. If Prepasses are required, tehy could easily be differentiated by 2 Render Presets (based on keywords again).
    No need to readjust all these source files manually - it's all automatic.
    And it would easily work with the old batchrender / command line rendering ...
    What do you think?
    Best regards, Peter
    www.xoio.de
    P.S.: I think Vray for Maya already has some kind of implementation. Phoenix FD, too.
    P.S.2: Just like in the framestamp ...
    I see what you mean, it would be great, but in the mean time, really, if you have more than 2 cams, just use RPManager...
    Stan
    3LP Team
      Just purchased a license yesterday .
      Still I guess could be a nice but simple addon ...
