There may be a way to do this already, if so, I'm all ears, but otherwise this feature would be really useful.
Sometimes you have a single material or object that requires more sampling, like say a grill on a vent whose holes are created with a transparency map.
Notice how the little circles don't sample properly, and some are missing (Adaptive 1 and 4)
Trying to fix it using more max samples doesn't' help much (Adaptive 1 and 16)
If you increase the samples (Adaptive 4 and 4), you get a nice smooth grill...
But you've now wasted a lot of samples on the rest of the scene that didn't need it. This wastes rendertime, you really only needed the extra samples on a single object. Of course there are other samplers to use, some of which may do a better job, but I would assume they are still using more samples on objects that don't require it to fix the object that does need it.
I'd like a sampling boost added to the Vray Material AND to the object properties, so you can choose whichever method works best for your particular situation. Sort of like a Subdiv setting, except for overall samples instead of just the reflections.
- Neil
- Neil
