Load VRimg in VFB and keep the same buffer
  • Load VRimg in VFB and keep the same buffer
    Would it be possible that once a VRimg is loaded in the VFB (according that the size and all the elements are the same) that the new render keep the current loaded vrimg and append the new renders to it?
    That way it's easy to reload the high ress from a previous session and increment the new changes so that when saved, the whole image is saved.
    Currently, once my max crashes and I'm loading back my VRimg from the history, where-ever I have the selection of the new crop render not selected, it swap back to black at render-time, no way to increment changes as if we where in the same session.
    Am I doing something wrong?
    Cheers
    Stan
    3LP Team
    It should be possible to implement that - will make a note to look into it.
      Great, thanks Vlado!
      For some reasons it does work now, not sure what I did differently.
      If I trace back down when it work or not I'll keep you posted.
      Cheers
      Stan
      3LP Team
        Well on a first try I couldn't get it to work either (the image cleared with black at the start of the render), so there is definitely something odd going on.
