Omit Render Elements from Corrections Control
  • Omit Render Elements from Corrections Control
    So since moving to vray 3.0 (which is great by the way, congratulations for that!) we have developed a slightly different workflow.
    Instead of using reinhard burn, we are using linear workflow and tweaking the burn and exposure controls in the frame buffer.
    This works great until it comes to batch rendering overnight and the RGB multimats come back with the exposure shift, burn and sometimes curves baked into them.
    It would be great if we could omit the corrections from the render elements.
    Regards, Dan
    Hm, right. Will need to solve that. Do you think exposure should be applied (it's just a multiplier anyways), or we shouldn't apply anything?
      As we save out in 16bit EXR (32bit is generally too heavy to work with) it would be better not to apply anything, as attempting to pull the masks back in Photoshop can mess up the edges.
      But then I think in some scenarios you would want your other passes, reflection, diffuse, lighting etc. to be affected. So I suppose a per element option would be better.
      I don't know how much of a headache that would be to implement?
      Dan
      P.S. I should point out that AO (using extratex & dirt ) and Zdepth passes certainly do need excluding from the corrections too.
        Hi Vlado,
        Do you think this is something that may be resolved any time soon?
        chris
        www.arc-media.co.uk
          +1 for this. I am using the Highlight Burn function in the VFB a lot lately, very useful feature. Problem is that it is also applied to the multimattes. So the values are off afterwards. Would be nice to exclude them.
            yep.. i flagged this behaviour a fair while ago.. its definitely not desireable.
              cc should affect only RGB element by default to keep things simple.
              Marcin Piotrowski
              youtube
                Any news about this?
                I'd love that the correction controls are not applied on the multimatte elements!
                Please Vlado go for it please!!
                Thanks
                  Unfortunately not yet, but I hope to be able to fix it for the next major update.
                  Tashko Zashev | chaos.com
