override auto exclude all vraylight material
  • override auto exclude all vraylight material
    Hello, in archviz, it is a very time consuming to look for all material with vray light to exlude them from override. So having an auto exclude for such material will be a real time saver.
    Ok, will look into it.
      thanks Vlado.
      Please keep in mind that the vraylightmtl can be part of multi material!
        Yes, which makes things more complicated
          Maybe this can be implemented in the wish I have to exclude by material instead of object?
          A.
          www.digitaltwins.be
            Yes! good idea !
            Excluding materials by type would indeed be very clever, maybe using some wildcards as well. We could then envisage some "combos", for example excluding VRay Light material + materials with name containing *glass* ... just a thought
            Nicolas Caplat
            www.intangibles.fr
              Stay tuned.. I have something very cool to show with this very soon...
              Maxscript made easy....
              davewortley.wordpress.com
              Follow me here:
              facebook.com/MaxMadeEasy
              If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
                Originally posted by fraggle View Post
                thanks Vlado.
                For so many reasons I would never have a VraylightMtl in a multi-sub-material.
                A script to detach any IDs with VrayLightMtl shouldn't be too hard to write... (I'll have a go when I get a moment).
                Follow me here:
                  For design it is the reverse.
                  You can always change you design when everything is part of one poly. If you detach it, then you have to start everything from scratch.
                    There is a procedural way to have them as another object using MCG that I'll look into for you.
                    Follow me here:
                      The simplest way to do it procedurally is to detach the faces as a clone and then put a Volume Select Modifier on with it set to Material ID and choose the ID and then put a DeleteMesh modifier on top. That way you can go back in and change your model, but you'll need to re-detach the Polygons every time you adjust that.
                      Follow me here:
                        Another option would be to have a script that created a Shell Material with your regular material inside it and then a copy of the material in the other slot which was set up for the overrides and then you just had a script which changed the render material from one to the other.
                        Follow me here:
                          thanks Dave for all the solutions you have in mind.
                          I've never ever write a single line of maxscript! Maybe I will do better with the new graphic tool available in max 2016.
                            Ok I may have gone to town a little bit on this, but it was pretty simple, this script allows you to make a chalk setup but keeping all VrayLightMaterials and Refractive VrayMtls (so you can keep glass in your chalks too). It uses a shell material to store the original material so you can switch back and forth, you can remove the Shell Material at any point too.
                            It gets the Chalk setup from one of the material editor sample slots, use the Compact Material Editor if you don't know where to find these in Slate.
                            EDIT - GET THE LATEST VERSION FROM MY BLOG HERE:
                            https://davewortley.wordpress.com/20...-mat-switcher/
                            Follow me here:
                            • #15
                              whom,
                              first time I heart about "chalk" mtl!
                              I will try it asap I'm out of an urgent project. Anyway, it's always urgent nowadays.
                              Thanks a lot.
                              Code:
                              --Written by Dave Wortley
                              --http://davewortley.wordpress.com
                              --MaxScript Made Easy
                              --2015
                              --This Script Converts your materials on all your objects to be in a Shell Material which allows you to store a chalk setup, and switch from your normal render setup to chalk rendering excluding Vray Light Materials and any Vray material which is refractive.
                              try(destroyDialog RL_ChalkMatSwitcher)catch()
                              rollout RL_ChalkMatSwitcher "Chalk Mat Switcher" width:200
                              	label lbl_a "Get Chalk Material from" align:#left
                              	checkbox chk_VrayLightMtl "VRayLightMtl" checked:true
                              	checkbox chk_RefractiveMaterials "Refractive VrayMtls" checked:true
                              	spinner spn_ID "Material Editor Slot:" type:#integer range:[1,24,1]
                              	button btn_createChalkSetup "Create Chalk Setup" width:170
                              	button btn_goChalk "Go Chalk" across:2 width:80
                              	button btn_goMaterial "Go Material" width:80
                              	button btn_removeChalkSetup "Remove Chalk Setup" width:170
                              	on btn_createChalkSetup pressed do
                              		ChalkMat = meditmaterials[spn_ID.value]
                              		for o in objects do
                              			if o.material != undefined and classof o.material != Shell_Material do
                              				theMat = Shell_Material name:(o.material.name + "_Wrapper")
                              				theMat.originalMaterial = o.material
                              				tempMat = copy o.material
                              				if classof tempMat == multimaterial then
                              					for i = 1 to tempMat.materiallist.count do
                              						local submat = tempMat.materiallist[i]
                              						tempMat.materiallist[i] =  Case (classof submat) of
                              							VrayLightMtl: (
                              								if chk_VraylightMtl.checked then
                              									submat
                              								else
                              									ChalkMat
                              							VrayMtl: (
                              								if chk_RefractiveMaterials.checked then
                              									if submat.refraction != (color 0 0 0) then
                              										submat
                              									else
                              										ChalkMat
                              								else
                              									ChalkMat
                              							Default: (
                              								ChalkMat
                              				else
                              					tempmat = chalkMat
                              				themat.bakedMaterial = tempMat
                              				themat.viewportMtlIndex = 0
                              				themat.rendermtlIndex = 0
                              				o.material = theMat
                              	on btn_goChalk pressed do
                              		for o in getclassinstances Shell_material do
                              			o.viewportMtlIndex = 1
                              			o.renderMtlIndex = 1
                              	on btn_goMaterial pressed do
                              			o.viewportMtlIndex = 0
                              			o.renderMtlIndex = 0
                              	on btn_removeChalkSetup pressed do
                              		for o in objects where o.material != undefined and classof o.material == Shell_Material do
                              			o.material = o.material.originalMaterial
                              CreateDialog RL_ChalkMatSwitcher
