Dongle-less V-Ray......
  • Dongle-less V-Ray......
    Would make my life a whole lot easier......
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    You'll get it... we've been working on an offline+online licensing system for a while now. Our plan is to make an experiment and release V-Ray for Modo without dongles in a couple of months, see what problems come up, fix them, and then introduce that to V-Ray for 3ds Max and Maya towards the end of the year.
      That is fantastic news
      I'm currently communicating with support with my dongle / wibukey / install issue and that news is Christmas come early
      Thanks Vlado
      Jez
        That sounds good to me. The office cleaner managed to knock my dongle out of my workstation recently, causing me some grief! I now have it plugged in at the back of the machine out of harm's way...
        I wonder if you might consider enabling the license to be used on multiple machines (not simultaneously obviously). As in enable us to work from home on a home workstation using the same license as we use at work, in the same way we can with our 3ds max licenses. This would be hugely welcome.
        Alex York
        Founder of Atelier York - Bespoke Architectural Visualisation
        www.atelieryork.co.uk
          That's not a problem for the online license, but obviously you need to have active internet connection. You can also borrow an online license for use on a specific machine in offline mode, but you need to remember to return it if you want to move it to another machine.
            Brilliant.. that's going to work very well then. I presume that if your internet connection drops mid-render it would still complete the render?
            Alex York
              Yes, of course.
                Yes, of course.
                Fantastic!
                Alex York
                  You can already do this. all our licenses are on a single machine in the new york office, everyone in the miami office checks them out through the day and i can check them out to use one while i'm at home too.
                  e: you may just be making sure this can still be done when it's switched over, sorry.
                    They are news important for me who support a V-Ray license.
                    Is a borrow license returned automatically in specified time?
                    The borrowed machine may be broken down or stolen.
                    A license system is The RLM or ChaosGroup original?
                    OakCorp Japan - Yuji Yamauchi
                    oakcorp.net
                    v-ray.jp
                      It will be fine, generally. It is renewed automatically after some time. If the machine is offline, the license is returned to the online pool.
                      It is our own.
                        This is news to me. When I asked support about it recently I was told that it wasn't possible at all to use your license in a separate location without moving the dongle.
                        Alex York
                          From what I can see in our system (Ticket #135688 ) my colleague Greta Lazarova provided the following answer:
                          V-Ray uses a floating licensing system and it can obtain licenses from the V-Ray license server, running on any machine, which can be accessed through your network, or even over Internet.
                          Which means that it is possible to use the license in a separate location without moving the dongle by accessing it through the network or over Internet.
                          Would you please check our reply again and let us know if the provided information is different from the above one?
                            Hi Svetlozar,
                            I can't seem to find any of the emails at the moment for some reason. I went away with the clear impression that in order to do what I wanted to do I would need a new license, but perhaps I misunderstood. I'll see if I can dig out the emails.
                            Edit: found the emails. For some reason that reply about the internet method went into my spam so I missed it. I'll look into this! Sounds like it should work fine, assuming that the internet connection doesn't drop.
                            Alex York
                            • #15
                              I used to do this at work all the time using logmein hamachi which was a free drive sharing utility. You ran the software on your work and your home machine and added them both into a pool of computers. Any shares you had set up on your work computer were then easily mappable on your home computer using hamachi's technology which handled all the VPN stuff in the background for you and just gave you a simple ip for the other computer. As well as sharing drive mappings, hamachi also shared ports. I had the vray license server and dongle running on my work machine, so it was easy to connect to the vray license server using the ip from hamachi and then whatever port number you were using for your vray license server.
                              The current company I'm working for has a much more closed off firewall though so I can't do the same thing as easily.
