Displacement: Water level based on map.
  • Displacement: Water level based on map.
    Hi there,
    I thought it could be nice to have the option to use a map to determine the water level on a VrayDisplacement mod.
    If the water level map is the same as the displacement map, only with an offset value, the result could be a displacement with thickness.
    Guido.
    The water level only clips geometry, it doesn't create new geometry?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
      I think it works like a VRayClipper - it clips geometry as a plane, though would be pretty cool to have an option to use a map with different clipping levels.
      Available for remote work.
      My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
        It could be done I guess... Will make a note to look into it.
