Lens breathing to "0" as standard
  • Lens breathing to "0" as standard
    Can we please have the lens breathing value to "0" as standard, 1 is way to harsh with small cam-target distances (from over 40 deg it goes down to 0,5) and it's f***ing up with camera matching and camera export scripts.
    Just have here 1000 frames with a changing FOV because of lens breathing and the exported cam don't match in compositing.
    Or is this an Autodesk thing?
    Valentin
    ...forget Warp 9, engine-room please switch to Vray-speed...
    The new Max Physical Cam, is an Autodesk thing.
    A.
    www.digitaltwins.be
      chaos group coded the new max physical camera.
      WerT
      www.dvstudios.com.au
        Not exactly, we just gave them away the code for our V-Ray camera and they built the code of the Physical Camera around it. You should report any requests for the Physical Camera to Autodesk.
