file overwrite confirmation
  • file overwrite confirmation
    I wish the file overwrite checking algorithm would run before anything else did!
    It happens so many times, that I hit render and go make a cup of tea and come back to see: 'are you sure you want to overwrite the exr?' Dialogue box instead of half a test render.
    Vray seems to do a LOT (30s - 1min) of work before it checks the file.
    WerT
    www.dvstudios.com.au
    I have a Pre-Render check script. I'll see if I can work something into the next update for you...
    Kind Regards,
    Morne
      Ok, will make sure to improve both things (startup time and file checking).
