render 3dsmax standard zdepth element with vray
  • render 3dsmax standard zdepth element with vray
    Hi i noticed a difference in zdepth
    I was using the demo of VFB+, so i could switch back and forward zdept/vrayzdepth.
    Yet the standard 3dsmax zdepth element had much nicer dof then
    in comparison too the vray zdepth element.
    both have the same min/max values.
    so is it possible that you can render 3dsmax standard zdepth element with vray.
Name:	zdepth 3dsmax.jpg
    Is the 3dsmax depth channel clamped and the vray one not?
      hi joconnel thks for your reply.
      but no, i have checked/unchecked those options.
      like clip boundries, clamping, invert zdepth.
      in order too check the difference in rendering.
      i setup my scene using scanline and adding vrayzdepth and standard zdepth,
      Then swith too vray. yet both scanline and vray will display a totally different zdepth and thus Dof.
      "also with gamma on or off"
