Just wanted to add this to the wishlist in case it got lost in my previous thread.
Can you please add an option to the command line stand alone (sa) denoiser that could save the file with an offset for the frame number.
Right now, I can denoise images sequences over the network via backburner. However, this only works when the frame numbers start at 1.
My current workflow, is I render out an image sequence and set the frame number offset in max so the files save starting at 1. Then I can run the sa network denoiser on multiple nodes. But all my image sequeces are saved starting at 1. I have to use a renaming tool on each sequence to rename them back to the corresponding frame number I am working on in max. If the sa denoiser had an offset, I could handle this step during the denoise. Thanks.
