View Vray Triplanar Textures in viewport
  • View Vray Triplanar Textures in viewport
    It would be great to be able to see VRay Triplanar textures in viewport when the bitmap preview button is toggled.
    Thanks Chaosgroup.
    -Alex
    I would also want to be able to see the texture normally in the material editor when I add a triplanar texture map. The bitmap texture disappears as soon as I add it and becomes just a solid color which is really inconvenient when building and previewing my material in material editor.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      There was a trick to the ME issue, but it should be working generally. Can you post an example where it doesn't?
        Actually, I think I found why some materials showed just plain color in the preview window. I had some objects in the scene that were scaled 10-100 times with the scale tool and the scaling was not zeroed. This had caused me to use 10-100 times smaller scale for the triplanar texture in order to look good in the render.
        Aleksandar Mitov
        96GB DDR5
          My issue is, I can't see a correct map projection in the viewport while using triplanar map. The render is just fine. The model was made of a plane just extruding the edges. Using a box, teapot or sphere or whatever solid from max (which has UVs actually already), the triplanar looks good in the viewport as well but a custom geometry without UVs. Max 2018, vray 3.6
          ah, dang, wrong thread probably? sorry for that.
            I'd literally do anything to have this feature.
            CGI Artist @ Staud Studios
              Any update on this?
                Was wondering if there is any update on this as well.
                The representation of the VrayTriplanar is in the viewport is very off from the render.
                This would be so helpful.
                Thanks
