Auto Backup
  • Auto Backup
    Hi guys,
    My scene just crashed after working on it for an hour and there's no backup saved, my auto backup is enabled with an interval of 10 minutes. I've been rendering and using IPR on and off throughout.
    Is there any chance that the autosave function could be improved? I realise this might be a job for Autodesk or perhaps needs working with Autodesk to fix.
    Would it be possible for autosave to function while IPR is active if the user desires it? This is a guess but it seems like the autosave timer resets or skips after rendering, even if it was triggered immediately after the render has stopped it would be really helpful.
    Thanks,
    Max
    Freelance 3D Generalist
    www.maxwood.co.uk
    Are you sure you're checking the right project folder. I've had the same issue thinking it saved to another folder. But all this time it was a complete different folder. Check your user folders.
    A.
    www.digitaltwins.be
      Customize > File I/O > AutoBackup
      However, I have had a similar thing happen a few times in the past.. One time it was failing to save any backup files for whatever reason. So I just changed the path to a folder on my desktop and not had the problem since.
      I think the last time, may have been due to a directory string longer than 255 characters
