I would love it if there was an option to specify the Real World scale length AND width of a triplanar map. Not all maps are perfectly square. At the moment you can only specify 1 size which assumes that your map is perfectly square. If you use a rectangular map then it doesn't display the map in the correct proportions.
Why not add same RWS as in max bitmap settings? Or does triplanar not work properly unless the map is square?
