Render multiple views at the same time
  • Render multiple views at the same time
    Here's a wild idea:
    I do a lot of lookdev on assets where I need to render several different views every time I make a change, so I can see how it reacts at every angle.
    It would be so cool to be able to create 4 cameras, and render them at the same time, into one image in the frame buffer, which can then be treated as any other render with history and AB wipes and color corrections and such. Best I can do right now is a script that renders the different views in succession.
    It can be done in Cinema 4D, where you can use render the view of a camera in the scene as a texture in the same scene. If you apply it to a plane, that becomes a becomes a sort of live "monitor feed" from that camera. It's not perfect, it has basically the same limitations as a mirror reflection, like less effective sampling and useless render elements, but it's a nice option to have, and has other creative uses.
    edit: oups, meant to post this in the Maya wishlist, but I suppose it'd be a universal feature.
    __
    https://surfaceimperfections.com/
    Good idea man. And good job on your texture packs. Bought them a few months ago.
      The "camera texture" seems like a neat idea and should not be too hard to implement, if that works for you. Will make a note to look into it.
        vlado
        Thank you! Wouldn't be the perfect solution, but I imagine this way would be much less work and just a generally useful addition.
        marksmanguy
        Thanks! Glad you like them
        __
          Yes I would use this all the time ! Good idea + 1
            Ver nice idea +1
              Can we sticky this post? - I want this feature now....it would just be too awesome to believe.
                Any news here?
                  Originally posted by 3D-Casi View Post
                  Any news here?
                  You can find news here https://forums.chaosgroup.com/forum/...-announcements
                    Any news here?
                    No, I'm afraid; this is still on the R&D list.
                      Originally posted by dgruwier View Post
                      Here's a wild idea:
                      Maybe you could do it with a complicated series of mirror objects
                      http://www.jd3d.co.uk - Vray Mentor
                        +1 for this please
