Rendered viewport is CPU or GPU processed?
  • Rendered viewport is CPU or GPU processed?
    The rendered viewport is processed using CPU or GPU? Is there a way to set it? If not, are you goinig to add it? if not, why?
    Viewport rendering is calculated based on your current V-Ray Engine you've selected in Render Properties.
    Ivan Shaykov
    chaos.com
      ok, I was suspecting it was like this. Thank you for confirmation
        I installed the beta version and the engine selection is greyed out.
        Anything I need change?
          Originally posted by grischa_fischer View Post
          I can see on my end that the V-ray Engine and Device selection do get greyed out while I have an ongoing viewport that's showing in Material Preview or Rendered view mode.
          This doesn't seem to be the case though if I'm rendering through the VFB.
          Try to set your viewports in solid or wireframe view only and see if that helps.
            Yeah, that does the trick...Thanks!
