Vraymaterial import and export
  • Vraymaterial import and export
    Hello.
    I would like to import a Vray material created in 3dsmax. Is this possible?
    I would also like to output the material for testing purposes.​
    Simply you will export the V-Ray 3ds Max assets as fbx then export vrmat for selected objects from 3ds max then imports fbx assets into blender after that in blender vray material use node called vrmat mtl
    You will need to specify the vrmat. File location And use the material name in blender in material name parameter in vrmat mtl node
    As I know there's no other way at the moment and the editablty of this material is limited check this link
    https://docs.chaos.com/display/VBLD/VRmat+Mtl
