Are Color mapping settings available?
  • Are Color mapping settings available?
    It seems not...if yes, where are they?
    There is a good chance they might not become available at all, since we're considering deprecating them at lest for now. The V-Ray Frame buffer can do all of those in a much better way and most importantly you don't need to re-render to see the final result. Whatever color manipulations you do in the VFB are going to be applied to the viewport rendering as well.
    Ivan Shaykov
    chaos.com
      Well...surely have a way to set back from the VFB to Blender UI the color mapping settings is useful but I think that it's a bit convulted for everyone that uses intensively the rendered viewport as, to set a color mapping, you have to run, at least, one time the VFB, set the color mapping mode and settings and then come back to the Blender and continue working with the rendered viewport.
      Anyway, we're here to testing...so if you'll add it in this way, we'll see if it's like I think or not.
        Having your feedback about any changes we consider making is also important, and what you bring up as a point makes complete sense. The decision is not final after all. Thank you for sharing your thoughts with us.
        Ivan Shaykov
        chaos.com
