Chaos Cosmos models Intensity as Opacity not working.
  • Chaos Cosmos models Intensity as Opacity not working.
    Both Cpu and Gpu not working.
    Models use many times Out Intensity connected to Opacity Grayscale input and it seems not working. When using Color connected to Opacity Colored input, Opacity looks correct.
    Left image is original material and right image uses Color to Opacity colored. Model is Mountain Alder 003
    Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    Hi JuhaW, Great catch! I've logged this on our end under request number (VBLD-1017). In the meantime, you can either change the Opacity Type to Grayscale Opacity inside the Properties panel or connect the Out Intensity to the Opacity Colored socket—both of which will produce the correct result.​
    Daniel Kapsazov | chaos.com
