VrayMat Reflection color questions
This topic has been answered.
  • VrayMat Reflection color questions
    I'm testing the VrayMat features and there is something I can't understand if I'm wrong or not.
    I'm referring to the reflection color with the Metalness parameter set to 0 (dieletric material).
    The context is a scene with a white closed box, one white light, one camera with a neautral white balancing and 3 objects.
    One of this objects has reflection material.
    If I set the diffuse to white and the reflection color to green I got this
    I set the diffuse to another color (for example red) and the reflection to green, I got this
    Are these correct results?
    The one with white diffuse seems quite uncorrect... am I wrong?
  • Answer selected by daniel.kapsazov at 04-09-2024, 12:43 AM.
    Hey,
    I think both examples aren’t physically correct since there aren’t many real-world materials that reflect colors outside the grayscale. In ray tracing, this setup is more for artistic effects than photorealism. This effect is controlled by the “Preserve Energy Mode” option in V-Ray Material, which isn’t visible in the V-Ray for Blender builds right now, but we’ve noted to add it—thanks to your post!
    For more info, check out this documentation page:
    https://docs.chaos.com/display/VMAX/...gyPreservation
    Cheers,
    Milva​
      Hey,
      Cheers,
      Milva​
      Milva Perkovich
      QA department
      Chaos Group
        Originally posted by milva.perkovich View Post
        Hey,
        Cheers,
        Milva​
        Thank you.
        I was suspecting that was that option but, as I couldn't try it, I wasn't certain about it.
