Changing UV is not updated during rendered viewport
  • Changing UV is not updated during rendered viewport
    - Activate rendered viewport
    - select an object
    - go to edit mode
    - change the UV layout
    - in the rendered viewport the UVs still unchanged
    - exit edit mode
    - UVs are changed
    Is it designed like this and it's planned to work like this?
    Thanks for reporting this, bardo. I don't think this behavior was planned. I will log it on our end and get back to you once I have more information on the matter. (VBLD-1009)
    Daniel Kapsazov | chaos.com
      Hi bardo, I just wanted to let you know that after a discussion with the Development team, it was brought to my attention that currently, we don't support the export of changes to geometry-related data while in Edit mode.​
        ok. Understood.
