Vray Dirt - Affected by (exclude/include) feature seems bugged
  • Vray Dirt - Affected by (exclude/include) feature seems bugged
    I did this.
    - A plane with a material with a VrayDirt texture connect to diffuse color
    - Added a sphere and a cube
    - Added the sphere as "Include" object in "Affected by" feature
    - Everything is rendered correctly with just the Sphere affecting the plane
    - Change "include" to "exclude".
    - Plane correctly affected by the cube
    - Remove the Sphere from the "Object" field in the "Affected by" feature
    - The rendering seems still using the "Sphere" object following the "Exclude/Include" option.
    - You have to exit from the rendered viewport, go to shading viewport and then come back to rendered viewport to see renderer not using anymore the Sphere.
    The strange thing is that if you add an object as "Exclude/Include", the rendered viewport is updated correctly but if you remove the Sphere from the object field, the rendered viewport is not updated.
    We value your feedback! This issue is already known and is being tracked along with other similar issues related to the Include/Exclude lists of various V-Ray plugins. If you encounter similar problems with any other plugins, please share them here so we can identify and address as many as possible.
    Milva​
    Milva Perkovich
    QA department
    Chaos Group
