And same here.
V-Ray Sky node, Sun option selector should show Sun objects, not Sun objects data
Hi JuhaW, could you specify exactly what the problem is with the Sun selector? Information such as the build number being used, a screenshot, or a detailed explanation would be appreciated.
Lets add a new "VRaySunLight" or "VRaySun and Sky" to the scene, rename VRaySunLight object as "Sun". Then go to the Node editor and select V-Ray Sky node and you'll see its properties (Tab>Node>Properties>Options>Sun)
Sun selector is showing Sun objects data block name, not the object (this example "Sun") name.
Versions: All V-Ray 6 and V-Ray 7 versions.
blender_KfRuP6A8xg.jpgAttached FilesLast edited by JuhaW; 28-10-2024, 07:06 AM.Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
- Likes 1
