V-Ray Node Editor: Dissolve Node doesn't work
  • V-Ray Node Editor: Dissolve Node doesn't work
    In the Blender's Node Editors "Ctrl + X" Should dissolve Nodes, while remaining the initial connection to the last node in chain.
    For Example: V-Ray Bitmap --> V-Ray Color Correction --> V-Ray Mtl
    If V-Ray Color Correction is selected, and i press "Ctrl + X", it deletes the node and the Connection from V-Ray Bitmap to V Ray Mtl
    when it should actually remain connected as in V-Ray Bitmap --> V-Ray Mtl
    Hope this makes sense.
    Hi andrej_timotic, thanks for your report! We are aware of this situation and are looking into ways to implement support for this and other features, such as Node Wrangler. However, due to how Blender operates under the hood, we are currently unable to do so. Nonetheless, your report is being taken into consideration and has been logged on our end.
    Daniel Kapsazov | chaos.com
