Viewport rendering error
  • Viewport rendering error
    Hi, while using viewport render using cpu and move the scene, rotate etch, it says "No connection to vray renderer, try a few min later" while using gpu it says like the attachment and after that says no connection to vray renderer and stops interactive viewport render..
    Hello kenancakir,
    Thank you for reaching out. To aid us in our investigation, could you provide a bit more information regarding the issue?
    • V-Ray for Blender version – Which version do you have installed?
    • Reproducibility – Does the issue occur only on GPU?
    • NVIDIA drivers – Could you try installing the recommended NVIDIA drivers supported by V-Ray (version 566.14)?
    Daniel Kapsazov | chaos.com
      Hi, daniel.kapsazov I use Blender 4.2.6.0, sorry i corrected the first message, it occures both with cpu and gpu, i am using the latest nvidia drivers, not the recommended one.
        kenancakir In that case, could you check if you are logged into your Chaos account by going to V-Ray > Chaos Account?
        Additionally, it would be helpful if you could provide a screenshot of the following page on your side:
          I checked and i am signed in.. I noticed, as soon as i import a vrscene via Vray geometry, problems started..
          Edit : I tried both cpu and gpu / rtx viewport rendering and they worked nice.. My Sketchup Vray6 exported vrscene imports cause the problems..
            kenancakir It would be extremely useful for us if you could provide the .vrscene file that causes this issue. Could you please upload it here?​
              Hi, here is the mediafire link of my vrscene (I mean one of them, because all of them has that error) :
              https://www.mediafire.com/file/c1zsl...1.vrscene/file
