Displacement
  • Displacement
    Hi. It's a rendering using displacement map and modifier subdivision surface.
    It's a rendering using displacement map and V-Ray Subdivision
    With these settings.
    I want to use V-Ray Subdivision. But you see what happens. Am I doing it right?​​
    Hi konstantin_rybakov, V-Ray Displacement and Subdivision do require a bit of renovation on our side, but regarding what you’re reporting, it looks like the issue might be related to the “Keep Continuity” option in V-Ray Displacement not being toggled on.
    Could you please check if enabling this option makes a difference? Also, if possible, could you share the scene with us so we can test it on our end as well?
    Daniel Kapsazov | chaos.com
      I used the “Keep Continuity” option, but it didn't help.
      Here's the file. Here I used a different displacement map, for testing, but the problem is the same.
      https://drive.google.com/file/d/1HtJ...ew?usp=sharing
