I was just trying out Vray for Blender and started setting up this scene with some trees from the Chaos Library.
It seems like the position of Chaos Library objects in the render is determined by their origin and not by the actual mesh position in the viewport.
Is there a way to fix/change this? I know I can put the 3d Cursor on the project origin and then the origin of the imported assets will be correct, but this seems rather unpractical as I want to move around the 3d Cursor so that I can instantly place the objects were I want them to be and its also useless if the objects have a completely different position when changing the view to rendered.
This happens when I switch the Viewport mode to rendered, I start a production render or use the interactive render in the Frame buffer, so basically as soon as vray renders the scene
​Blender version: 4.2.7 LTS
Vray For Blender 7.00.10
Note: This ONLY happens with Chaos Assets, the house in the foreground is modeled in Rhino and has its origin somewhere else
