vray proxy not working in blender 4.3
  • vray proxy not working in blender 4.3
    hi there,
    I am experementing with the vray proxy workflow.
    the documentation here seems to imply that an alembic can be imported to vray proxy:
    https://docs.chaos.com/display/VBLD/V-Ray+Proxy
    But when I try, I receive an error and nothing imports. "failed to read .vrmesh file. Indicating that .abc cannot be read after all?
    So I tried converting to vrmesh file and importing via adding a new vray proxy, only to receive the same error, failed to read .vrmesh file.
    I tried blender 4.2, it seems it can read the .vrmesh file at least. Not alembic. But in this case I do not have any options for vr proxy under the data tab in blender, and the alembic I created does not animated as I expected.
    I was intending to just import a cloth sim I created in an external app as .abc and render with vray blender. But I get no animation when I render a imported .abc. So if there is any workaround I am listening!
    Thanks!
    Hi Leo, I’ve tested the import of .abc and .vrmesh files using the latest release build for Blender 4.3, but I couldn’t reproduce the issue on my end.
    Could you provide a screenshot of the console showing the error message you encountered during the import? Additionally, if possible, attaching the problematic Alembic file would be greatly appreciated.
    Milva Perkovich
    QA department
    Chaos Group
      This seems to be the error im getting
      and my .abc https://drive.google.com/file/d/1_uc...ew?usp=sharing
        Hi Leo,
        Thanks for the detailed info. The problem you are facing is that the add-on cannot find one of the tools that it needs in order to perform the import, which might be if the addon was installed in a non-standard location. We know about the issue and it has already been fixed but the fix hasn't been published yet.
        BTW, support for animated alembics is on our development schedule but still not available.
        Iavor Vajarov
        V-Ray for Blender Developer
        chaos.com
          Originally posted by iavor_vajarov View Post
          Hi Leo,
          Oh so even if I could import it, it would not animate? Are you aware of any other way to import animated to geo that will render?
            Unfortunately, not at the moment.
            Iavor Vajarov
            chaos.com
