Hi guys, my problem is this. I used Blender with the demo version of vray stanalone. This works for me. I have now bought the advance version and does not work. What can I do?
Problems using Vray stanalone
It is windows 7 64 bits. How do I activate the license?
I downloaded license server.
The install.
After I install vray stanalone.
Finally Vray Blender.
In blender I update the exporter.
When I give does not appear to render frame buffer.
But if instead of installing Vray adv 2.0 Standalone install demo if it works.
Isn't there a change in licensing? With the full version, you have a dongle you need to install along with the drivers in order to run the license server. Have you installed the dongle and Wibu-key drivers? Also, when you run Blender, you should select the option under Help - Toggle System console - then you can see the errors reported.
Dmoya, this is the first thing you should always do when smth strange happens in Blender: https://github.com/bdancer/vb25/wiki...)#wiki-General
