Vrayblender 86x cant find my vray 86x for maya (and standalone)
  • Vrayblender 86x cant find my vray 86x for maya (and standalone)
    Hi
    i hope have good time
    my windows was crashed and i forced to use my old windows (86X)
    i try to download last version of Vrayblender
    and inistal Vray for maya 86X
    but i think my blender cant find my vray paht
    can you help me to input manualy the path ?
    i try under lines - but i get unknown location error
    - %VRAY_PATH% - this variable shows where V-Ray Standalone is installed
    - %VRAY_FOR_MAYA_* - this variable shows where V-Ray for Maya is installed
    - %PATH% - this variable allows you to manually specify the location of V-Ray Standalone
    thanx
    I am Programmer,I have no life
    Read new prefs: C:\Users\ehsan\AppData\Roaming\Blender Foundation\Blender\2.69\c
    onfig\userpref.blend
    found bundled python: C:\Program Files\VRayBlender-2.69\2.69\python
    V-Ray/Blender: Writing scene...
    V-Ray/Blender: Writing frame 1...
    V-Ray/Blender: Writing frame 1... done [0.02]
    V-Ray/Blender: Searching in: VRAY_FOR_MAYA2012_MAIN_X86
    V-Ray/Blender: V-Ray found in: C:\Program Files\Chaos Group\V-Ray\Standalone for
    x86/vray\bin\vray.exe
    Clearing command queue.
    Traceback (most recent call last):
    File "C:\Program Files\VRayBlender-2.69\2.69\scripts\startup\vb25\render_ops.p
    y", line 1239, in render
    vb25.render.render(self, scene, preview=True)
    File "C:\Program Files\VRayBlender-2.69\2.69\scripts\startup\vb25\render.py",
    line 2120, in render
    export_and_run(init_bus(engine, scene, True))
    line 2075, in export_and_run
    run(bus)
    line 2055, in run
    layer.load_from_file(load_file)
    RuntimeError: Error: RE_result_rect_from_file: failed to load 'c:\users\ehsan\ap
    pdata\local\temp\preview.0000.jpg'
    why this forum delet the quite button and edite post ??
    i use other forum quote tag ([QUOTE])
      sorry for triple post
      this forum desable post editing
      i see my Taskmanager and see Vrayblender can find my vray and there is an Vray.exe
      "C:\Program Files\Chaos Group\V-Ray\Standalone for x86\vray\bin\Vray.exe"
      but i cant see any windows
        Well looks like it found it ok; what is the vray version? It looks like its a call for preview rendering - does normal render works?
        andrei.izrantcev@chaos.com
        Support Request
          Hi Andrey how are u
          i think reason of it is my Vray version :P
          2.0.0.1
            I update my Vray
            and again see this problem
            i just open my Vrayblender
            and press Render button
            Read new prefs: C:\Users\ehsan\AppData\Roaming\Blender Foundation\Blender\2.69\config\userpref.blend
            V-Ray/Blender: Exporting meshes...
            V-Ray/Blender: Exporting meshes done [00:00.00]
            V-Ray/Blender: Writing frame 1... done [0.00]
            V-Ray/Blender: Writing scene... done [0.01]
            V-Ray/Blender: V-Ray found in: C:\Program Files\Chaos Group\V-Ray\Standalone for x86/vray\bin\vray.exe
            [2014/May/16|14:47:38] Reading configuration from "C:\Program Files\Chaos Group\V-Ray\Standalone for x86\vray\bin\/vrayconfig.xml"
            [2014/May/16|14:47:38] ===============================================
            [2014/May/16|14:47:38] V-Ray Standalone EDU, version 2.20.01 for x86
            [2014/May/16|14:47:38] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved.
            [2014/May/16|14:47:38] Use -credits option for additional third-party copyright notices.
            [2014/May/16|14:47:38] Build from May 11 2012, 04:05:36
            [2014/May/16|14:47:38] Compiled with Intel C++ compiler, version 12
            [2014/May/16|14:47:38] Operating system is Microsoft(tm) Windows(tm), version 6.1, Service Pack 1
            [2014/May/16|14:47:38] V-Ray core version is 2.00.01
            [2014/May/16|14:47:41] Loading plugins from "C:\Program Files\Chaos Group\V-Ray\Standalone for x86/vray/vrayplugins/vray_*.dll"
            [2014/May/16|14:47:42] 103 plugin(s) loaded successfully
            [2014/May/16|14:47:42] Finished loading plugins.
            [2014/May/16|14:47:42] Reading scene file "c:\users\ehsan\appdata\local\temp\vrayblender_sta ndalone\scene_scene.vrscene"
            [2014/May/16|14:47:42] c:\users\ehsan\appdata\local\temp\vrayblender_stan dalone\scene_scene.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_environment.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_nodes.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_geometry_00.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_geometry_01.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_geometry_02.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_geometry_03.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_materials.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_textures.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_lights.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] scene_camera.vrscene: done [ 0h 0m 0.0s]
            [2014/May/16|14:47:42] Scene file parsed successfully in 0.0 s.
            [2014/May/16|14:47:42] warning: Unknown property "ray_max_intensity" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "ray_max_intensity_on" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "dr_overwriteLocalCacheSettings" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "dr_assetsCacheLimitValue" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "dr_assetsCacheLimitType" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "misc_abortOnMissingAsset" in object "SettingsOptions"
            [2014/May/16|14:47:42] warning: Unknown property "embreeRayPackets" in object "SettingsRaycaster"
            [2014/May/16|14:47:42] warning: Unknown property "embreeLowMemory" in object "SettingsRaycaster"
            [2014/May/16|14:47:42] warning: Unknown property "embreeHighPrec" in object "SettingsRaycaster"
            [2014/May/16|14:47:42] warning: Unknown property "embreeUseMB" in object "SettingsRaycaster"
            [2014/May/16|14:47:42] warning: Unknown property "embreeUse" in object "SettingsRaycaster"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_showMask" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_bundleSize" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_maxTime" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_threshold" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_maxSubdivs" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] warning: Unknown property "progressive_minSubdivs" in object "SettingsImageSampler"
            [2014/May/16|14:47:42] Scene created successfully.
            [2014/May/16|14:47:42] Objects in scene: 28
            [2014/May/16|14:47:42] Starting render sequence.
            [2014/May/16|14:47:42] Preparing renderer...
            [2014/May/16|14:47:45] error: Could not obtain a license (10061).
            [2014/May/16|14:47:45] Closing log - 1 error(s), 17 warning(s).
            i try to normal render ( didn't preview a material)
              I solve my problem
              i solve my problem
              Malware byte... ( antivirus block all Vray data :P)
              i delet it and solve the problem
              sorry Andrei for get your time
              and thanx to help me
                Glad to here, but now you are without malware protection =) May be this soft was just blocking the license server port?
                Support Request
                  Maybe
                  i didnt raed whats blocked port
                  But i uninstalled Malware because free license was finished :P
                  and vray after it was worked good
                  I think was for Blocked Port of Vray license
