memory gpu
  • memory gpu
    Hallo everyone, just a question:rendering with gpu, if i have two memory card in the same pc having one 3 gb of vram and 2 gb ,can i use the total or the one who have the highest memory?
    If you're using both GPUs the scene must fit into the smallest memory. Vray 3.5 does offer many improvements for keeping GPU memory usage low
      So is not convenient use a 1080 gtx 8gb in couple to a 580 gts 3 gb
        The GPUs work side by side - a bit like render nodes. Only GPUs that can fit the scene into their own memory will participate in the render.
          This FAQ should explain a few other ingredients things for you:
          https://docs.chaosgroup.com/display/...X/V-Ray+RT+FAQ
            thanks.I hope to test at soon.
              Being intersted to render with gpu: it's possible know the amount of memory needed?For exemple my scene often need about 10/12 gb ram,the same it's needed in gpu rendering?I read vray 3.5 optimyze the texture, but actually my scene cause an out of mem, with my 660gtx 2gb.
