Vray HDRI addon
  • Vray HDRI addon
    Original addon by Nicolas Priniotakis, I fixed it for Vray for Blender.
    It creates Hemi light if there is not and add light nodetree. Use UI panel rotation for hdri image rotation, it will rotate also Hemi light.
    Intensity is Hemi light intensity.
    Download: https://github.com/JuhaW/HDRI-lighting-Shortcut
    Video: https://www.youtube.com/watch?v=R0Vv0ryObCo
    Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
    THANK YOU! this is verry useful.
      this addon could have one improvement, if that is possible, collor brightness of image are verry dark, when intensity of light are set to 1, moast of the cases, I am using 1-2 light strength, my question is it possible to make image brigtness level independent adjustable, because I guess now it is using linear collor profile or something
        It is possible:
        : Click image for larger version
          Thank you, thank you, thank you!
          It works great, you also have to increase the "hemi" power value to have it emit the same amount of light as the "image" value.
          Windows 10 Pro, 2x GTX 1070, AMD Ryzen7 1800X, 32 GB DDR4 Ram, V-Ray Standalone/Blender, V-Ray 3 for Sketchup, V-Ray 3 for Modo
            afecelis: it was before that way, one value controlled Hemi lamp intensity and hemi lamp hdri image intensity on 3dview.
              Update: Synchronize sun and hdri image rotation.
                Very nice! Thank you Juhaw!
                  time saver, thank you
                    One thing JuhaW, is it possible to add an option to turn it off in the viewport when needed? Sometimes the hdr/exr is too heavy and consumes a lot of memory slowing down viewport performance. Being able to temporarily switch it off to work fluently would be a nice addition
                    regards,
                    Alvaro
                      This addon look great! Thanks, JuhaW!
                        afecelis: done.
                          wow! That was fast! Thank you JuhaW
                          I'm now modifying all my previous scenes with your addon.
                          regards,
                          Alvaro
                            If you have many 3dviewports on the screen, it'll change all of them. Off the record, every 3dviewport has own world background settings.
                            • #15
                              It works great as it is.
