pbr problem!
  • pbr problem!
    This morning I decided to give vray a chance.
    The perfect light, the global lightings that a pleasure, a delight.
    But..
    Then I try to pass a personal project, chan! problem with my pbr substance textures.
    I try with a simple and basic exercise, susane mesh and chan! problems! problems! problems!
    What am I doing wrong, or rather, what is wrong with the exporter?
    thanks
    I see a bit of specular highlight in the red material in vray render that didn't exist in the substance version.
    My guess is that you're using a roughness map in the glossiness slot (the're inverse). Try using a invert node and see what happens.
    architect at oona
      Hi leandro.
      The channels are correctly connected.
      In this case, it is likely to be a problem for the exporter.
      I do not know
      Thanks!
        Blend file with packed textures is more than 1000 words/images
        Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
          Excuse me, juhaw, I did not understand.
          I'm going to download the new build. Let's see what the tide brings ...
            He's saying that if you provide a simple test scene (blend file with textures) would be easier to help you.
            architect at oona
              Thanks.
              https://drive.google.com/open?id=1gb...uRBJOHFjDt2Z3E
                I found something, connect IOR-node Output, not Intensity.
                  Ohh thanks Bro!
                    Well, IOR is a float texture so "grey" output should be used, not sure why you think it fixed the issue. For "metalness" to work make sure you are on V-Ray Next.
                    andrei.izrantcev@chaos.com
                    Support Request
                      soon I will be!
